SOLUTION: Re-adjust your PSU Cables with force and put them in place. (24pin and 8Pin wires both)
Hey there!
Heres a fourth thread on the same issue. haha.
No idea if you've seen the recent ones but anyway.
Suspect is Corsair RM750x
The Issue :-
ASUS Anti Surge Triggering
> Thought the power surge from outlet caused it.
> Turns out PSU is ok i took it out of the case and using it since.
> Noticed ASUS Anti Surge not triggering afterwards, Concluded, Thermal issue.
Now recently
Random ASUS Anti Surge trigger after 8 hours of use.
> Tempreatures within 30c Operational. (PSU)
> Checked bios and saw +12V Rail at 11.131.
Some notes :-
Once it reaches a low and does a reset, it'll stay like that until i turn off the PSU for some time.
Usually under loads it would spike down to 11.56 and then back to 12.00
Now the help.
Is this worrisome?
Corsair mentioned about turning off ASUS Anti Surge.
But now after looking at this voltage drop I dont know if i should risk it.
Now i'm just new into the power supply mumbo jumbo as you know, because for the past 10 years i didnt have it now all of the sudden this (Since last year).
So do you think the input voltage from my outlet is causing it or the PSU is just bad?
Its hard to reproduce it to get it RMA'ed since it is very random and happens only at load at different times.
Update :- I've reattached the wires but this time harder, i noticed it went to 12.096. Before it used to idle at 12.000 never above.
Maximus VII Ranger
4770k
8gb vengeance
r9 390
2x 2TB Seagates
DVD/CD Combo Drive
RM750x PSU
Hey there!
The Issue :-
Now recently
Some notes :-
Now the help.
Is this worrisome?
Maximus VII Ranger
4770k
8gb vengeance
r9 390
2x 2TB Seagates
DVD/CD Combo Drive
RM750x PSU
