12v rail problem?
This is true. As power requirements grew the wire gauge would have had to increase quite a bit so 12 volts was the only option.
150 watts @ 12 volts is 12.5 amps
150 watts @ 5 volts is 30 amps
150 watts @ 3.3 volts is 45.45 amps
Higher current needs larger wire.
That doesn't make sense here's the rail ranges.
How are they seeing that it is only putting out 5 and 3.3? I mean you can not even boot a computer without 12 since the cpu regulators are powered from the 12 volt rail as are many other parts of the system(hard drive motors/fans/video cards/ect).
