1366x768 Crysis 3 MAX
jeraldtapz
66
I will buy a Haswell i3-4130
and a GPU
4 GB of ram and 450W Corsair PSU.
I chose Crysis 3 as a benchmarking game. Because if i can run this max, maybe i can run most of the games that are coming out for the next 6 months - 1 year.
What gpu should i be looking for at 1366x768 resolution?
I want to max crysis 3 at 40-50 FPS.
Since you didn't give a budget or anything, I'll just give you my basic info for a range of prices. If you have no preference for nvidia or amd and want a budget card, I recommend this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125443
This will be playable in Crysis 3, but will not be able to handle maxed settings
Performance card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127759
This card would be able to handle Crysis 3 at high settings. Ultra settings may struggle, and if you ever plan on increasing resolution, you will find it degrading very quickly.
High performance card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202080
This card will be able to handle Crysis 3 on maximum settings at a full 60FPS for your resolution. It will also handle any game currently out at 60FPS for your resolution.
My budget is $200 max. The GTX 660 is out of stock except for the Inno3D GTX 660 for $203. There is Sapphire R9 270 Dual-X OC here for $188 is this good enough? Since I am playing at a fairly low resolution i wan't to crank AA as high as it can. Is there a certain specification i should look for with respect to handling AA?
I have read that R9 270 is overkill for my resolution but i think that overkill = near-future proof. Do you think 750 Ti can Max Crysis 3? 40-50 FPS.
An i3 won't run crysis 3 at max consistently at 40fps. It will have sub 30 frame rate drops making for a bad experience. As for GPU idk I stick to 1080p so I have only testes at 1080p and only know those benchmarks.
Crysis 3 has a recommended requirement of i3-2120T/Phenom II X4 810 and a hi-performance requirement of i7-2600k/FX-4150(ABSURD i7>>>FX-4150) . So I think the i3-4130 which beats the i7-2600k in single core performance will be able to handle 40-50 FPS on Crysis 3. I know Crysis 3 utilizes more threads but the Haswell i3 is way better than the 4 core Bulldozer.
Thank you for the reply. I think I should be looking for fx-6300 or an i5 then. So Graphics wise do you think r9 270 will be enough to max it out if i get the fx-6300 or i5?
