1366x768 vs 1920x1080 heat generation and battery performance
knowledge2121
909
9
18,995
I am looking at two laptops(1366x768 vs 1920x1080) ... they both come with Intel iGPU....I am not doing any graphical intensive work...Just math software and some programming...
Am i right to think that the 1920x1080 one generates considerably more heat and has worse battery performance ? or are the differences negligible ?
many thanks
Not really, even under the limited graphical power the iGPU can do the heat generated wont really be the high. Just buy a laptop that has good cooling capabilities.
I agree get the 1920x1080 screen.
1) I believe there is still SOME increased power draw, possibly just due to the GPU itself processing more pixels but it's hard to guess since it depends on the hardware. Probably not too significant in a modern Intel iGPU.
2) No guarantee both laptops have the same battery life.
3) Backlight as said (AFAIK) is by far the biggest drain so adjust the Power Options so the brightness is the optimal balance of "bright enough" vs battery life.
4) By "heat" I assume you are referring to EXHAUST thus fan noise? I ask because the BACKLIGHT heat would have no effect on the fan that is mainly to exhaust the CPU/GPU heat.
So...
I'd concentrate on the following:
1) 1920x1080 just because:
https://www.laptopmag.com/articles/laptop-screen-resolution-ripoff
2) Quality/reliability matters the most too (try to find user reviews on places like NEWEGG... Amazon is no good since they mix similar items)
3) for CPU I recommend Intel that has 2C/4T (dual core with hyperthreading) not 2C/2T
4) if possible find a model that has an extra M.2 or SATA slot to add another drive (so you can backup data). It's hard to find out though what a model offers for this.
true...power consumption will be the same but I think iGPU(Intel UHD 620) generates more heat with higher resolutions and since it is close to the CPU it can raise CPU temperatures which in turn can cause CPU to reach its thermal limit which in turn causes it to clock down....is that correct ? or the difference is not that huge ?
Update:
If possible I suggest you make a BACKUP IMAGE using a tool like Acronis True Image to make a compressed backup to another drive (probably a USB HDD). I'd wait until you are all setup (e-mail etc) and if you don't setup an automated solution at least setup a software reminder to periodically make a new backup Image manually then DELETE the older backup.
Acronis True Image isn't free for the automated solution but it does have a cool feature where you can add a USB HDD and I believe if you are past due for a backup it will then just startup and do it.
*Assume that your laptop drive could simply DIE at any given second and plan accordingly (or at least get severe software corruption you can't fix).
So to be clear you should:
1) manual or automatically make a compressed backup Image (i.e. Incremental)
2) setup a REMINDER if necessary (i.e. monthly to just plugin your USB HDD?)
3) create a BOOT USB STICK to initiate a RESTORE. For example if your HDD dies you would:
a) buy new HDD/SSD of sufficient capacity and correct size (some must be 7mm thick not 9.5mm if SATA)
b) swap new for old physically
c) attach the backup USB HDD
d) insert Restore USB stick and boot
e) follow instructions to RESTORE the backup to the new drive
