Question 13900K No Overclocking.. Reaching 92c during 15 minute stress test.. Normal or I have something wrong? 9 percent CPU throttling "overheating detected
itzthrillz
20
Hello. Heres my specs/build
Case: Lian Li LI PC-O11 Dynamic EVO
Motherboard: ASUS ROG Maximus Z790 Extreme
CPU: Intel 13900K
CPU Cooler: EVGA CLCx 360mm All-In-One LCD CPU Liquid Cooler (swapped out EVGA fans for phanteks & set to exhaust position)
Thermal Paste: Removed EVGA's stock paste and used Thermal Grizzly Kryonaut.. using the spatula method
Case Fans: Phanteks T30-120 Fans (6 of them in intake position) . 4 for exhaust = 10 fans total
Graphics card: None yet (for now using intel's built in graphics)
PSU: MSI MEG Ai1300P
SSD: SAMSUNG 990 PRO SSD 1TB NVME M.2
Ram: G.SKILL Trident Z5 RGB Series 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6800 (PC5 54400)
Its my first build so I believed to have installed everything correctly. I don't plan on overclocking. My bios is set to pretty much "Auto" on everything since I didnt change anything except switch the ram profile to XMP I instead of XMP II.
I did a stress test to make sure everything was running correctly but after 15 minutes of running AIDA. I saw CPU temps were reaching 90 to 92* Celsius. I read that most people are saying anything over 90* is pretty bad.
I set my both my fan / pump speed to 90 percent using EVGA's software. 2100 RPM On fans & 2200RPM on CPU Pump
If this is not normal being that it should be a decent cooler. Could someone tell me what could be wrong?
Screenshot below of CPU temps on EVGA's software screen
View: http://imgur.com/Rw9TxaC
Aida64's results: Showing 9 percent CPU throttling with a message of "overheating detected"
Screenshot below
View: http://imgur.com/w7x52SH
CPU temp reaching 90c on EVGA's LCD screen
Screenshot: View: http://imgur.com/VzPRLpd
Coolant temp looks fine at 29c On EVGA's LCD Screen
Screenshot: View: http://imgur.com/QgUN1Gw
Screenshot of bios information (running the latest Asus rog Maximus z790 extreme bios)
View: http://imgur.com/jtjiXXz
Screenshots of voltage information on Bios
View: http://imgur.com/yHGt84l
View: http://imgur.com/BRfwru1
Screenshots of CPU Frequency & XMP I profile I switched to for RAM via BIOS. They have a XMP II option but decided to just use XMP I
View: http://imgur.com/Uh2yNEA
View: http://imgur.com/MNbIc4t
Screenshot of i9-13900K CPU reaching 4.89 ghz when running Aida stress test with AIDA statistics
View: http://imgur.com/xE6WsZZ
Screenshot Of CPU in an idle state at 4.42ghz with AIDA statistics
View: http://imgur.com/3Zag7dq
My room temperature is around 70 to 72 degrees as well
I never got a BSOD
CPU: Intel 13900K
Screenshot below
I never got a BSOD
Hello - I would like to chime in on this one. Most AIO coolers only run about 2500 rpm max speed and have a 28 cm core. I myself used to run a Corsair AIO with a 12900K. I too found out that the cooler just seemingly could not keep up with what I wanted out of it. Ended up building a custom loop from EK with a thicker core 360mm radiator with fans in a push/pull configuration and a pump that pushes 4000-ish rpm. In essence - if you want any hope of overclocking these newer K sku chips from Intel - you may need to get more significant cooling like myself. As another poster said - the higher speed helps push the coolant through the radiator at a pace fast enough for the fans to help dissipate the heat, but that alone may not be enough. You will likely need to invest in a heavier cooling setup to tame the beast. Undervolting will also help to some degree. Can lower temperatures as much as 5-10 C if done correctly. It isn't that you've done anything wrong - it's more likely that the P cores are zipping up so fast ( causing almost an immediate heat temperature rise out of the chip ) that it overwhelms the cooling solution before it can provide effective cooling. I too learned that the hard way. A speedy pump and a good thick radiator was my solution. Hope this helps.
Reactions: itzthrillz
Thank you for that. I previously had a pre-built water-cooled pc with those water blocks for CPU & GPU. Temps were always low but I just didn't like the yearly maintenance of taking all the radiators out. flushing liquid. refilling, cleaning all the water blocks etc. cause I had a terrible case/hard to work with so I decided for much less maintenance with AIO. I dont plan to do any overclocking at all. Im fine with the speeds I see now. Sometimes I see it reaching over 5ghz already without me touching anything in the BIOS
I just disabled asus multi-core option on bios and set to "enforce all limits" mode.. Did another stress test and this time I didnt see it saying "overheating" and no messages about CPU throttling but still I saw high temps sometimes ranging from 75 - 93 Celcius. Im assuming going by what you told me this might be the best I can do without messing with undervolting / switching back to water cooling option././ But yes this AIO reaches up to 3,000RPM max for pump and fan speed
Reactions: Why_Me
