1440p 144hz Monitor Help
HazDog
Commendable
Nov 10, 2016
37
Hi,
I'm looking to buy a new monitor that comes under 1440p resolution and 144hz, 27 inches.
I am asking the community for any recommendations. I have my eye on one or two but I don't know much about monitors.
Samsung CHG70 - which is curved
Samsung CFG70 - wwhich is 1080p but 144hz.
I am wondering whether it would or wouldn't be appropriate for a 1080p nowadays and whether or not it would look any good when the screen size is 27 inches.
Thanks,
GPU: GTX 1060 6GB
CPU: I5 6600K
RAM: 16GB 1866MHZ
Assuming, this is related to gaming, your specs are not strong enough to support 1440p/144hz together. You can go for a 1080p/144hz unit as long as you do not expect ultra on most games. But your card is best suited for 1080p/60-75hz ultra on most games.
HazDog
Commendable
Nov 10, 2016
37
Would you recommend me upgrading to a GTX 1080 and keep the cpu the same?
Recommended minimum GFX Cards (nVidia / AMD) for various resolutions on 144 hz monitors:
Recommendation is based upon "playable frame rates", not 143 fps. For example Witcher 3 @ 60 fps / GTAV @ 100 fps
1080p - 1060 3GB / RX 570
1440p - 1070 / None
2160p - None * / None
None exist as yet but when they drop (Acer and Asus postponed theirs from this month to 1Q 2018 because if yield issues). At that time it will be 2 x 1080 Ti or next gen stuff
As for size, it's all about PPI or pixel density. 27" at 1080p is not a good idea if you have normal vision. You don't want to have a PPI less than 96 or so if ya have normal vision and sitting at typical viewing distances.
As for CPU, Sandy bridge CPUs are still doing well in gaming boxes.
I know I would. Hellfire is right about the system being 1440p/144Hz challenged. The 1080 would help that. Are you looking at something like the G1?
https://www.newegg.com/Product/Product.aspx?Item=N82E16824009769 would meet your needs.
65 - 70 fps in say Witcher 3 w/ a 1070 is not enough ?
(4) 144Hz monitors here
I was talking about possible ultra settings on most games, as per my last post. :)
