Hello I'm stuck deciding between these two for my new PC build. As of right now I'm looking at a r9 390 for my gpu. So first of all will this be enough to play games at 1440p at 60fps with AA off because I heard it doesn't make a difference with 1440p. Or, to play 1080p at 90fps if not more? If I set graphics to high with no AA to achieve this will the graphics still be better than console? I may be able to get a gtx 980, but I'm worried about the vram not being enough, and it being $200 more, and the 390x only got about 5 more fps than the 390 so I didn't think that was worth 100 dollars
As for the actual debate what do you guys think is better? Right now I'm leaning toward the 144hz if I can achieve, because it will improve my performance, and feel a lot better in fps games, and for others I can always just crank the graphic settings back up. Also fps drops won't be as noticeable, and I really love how the Ben Q XL2411Z has the ability to get rid of motion blur. Though I'm not sure how bad it would be on a 1440p monitor. I have a plasma tv, and the motion is much better than led/lcd, so that's what I like, and are used to.
However 1440p would be sick looking not just for the higher resolution, but for the ips panel. Is there a big difference in 60 to 90 fps, and do you think it is better?
