1440p monitor display options
elitose
103
Will games that offer ultrawide resolution, specifically 2560x1080, have an option to play the game at 2560x1080 on 2560x1440 monitor with black bars at the top and bottom of the screen?
This is a decent video for making a custom resolution.
https://www.youtube.com/watch?v=9II4djWfKq4
To disable scaling, you'd need to go into your Nvidia control panel. Then click "adjust desktop size and position" on the left side. Then click the small circle thing by the "no scaling" option in the scaling tab. That'll just make it so you can have black bars without it stretching to fill your screen.
To test it before you get a new monitor (assuming you have a lower monitor now and you're wondering about getting a 1440p monitor), you could possibly make another 21:9 resolution like 1890x810 just to see if 21:9 will work with black bars on a monitor of a different resolution. (Just in games that actually support 21:9, of course)
If it...
I really like the ultra widescreen displays. However i know not every game supports them. For those games I would like to play them at full 1440p. However, for the ones that do I prefer 2560x1080. I would rather invest in a monitor that can do both rather than just a strict 2560x1080 ultrawide monitor where games would have to be played at 1920x1080 if ultrawide is not supported.
Do you know if its possible to play ultrawide compatible games at 2560x1080 on 2560x1440 monitor?
I'm still hoping someone has an answer to this. It would really help.
I don't see why it wouldn't be, but you would probably need to create a custom resolution in your drivers and disable scaling.
I do that to play old games at 4:3 1440x1080 on my 1080p monitor, so it'd probably work the same way.
Do you know of any youtube guides or other online tutorials on how to do that?
Do you have an Nvidia or AMD card? It's really simple on my GTX 660, but I have no idea about AMD.
I have a dual 770 sli setup.
If it works, the new resolution 1890x810 should show up in the list of available resolutions in a game's options menu.
But in actual use ofc, on a 2560x1440 monitor, the custom resolution would need to be 2560x1080.
I'll give it a shot. Thanks!
