Hi everyone
I am planning to buy a complete gaming computer and have finalized every part (see list below) except the monitor. I don't want to spend too much on the monitor because my overall budget is limited. I will get the RX 480 8GB version and I won't upgrade for another 2-3 years. Hence I expect that in the future my fps in games will definitely be in the 40-60 range and some games may possibly drop to 30 after 3 years. I only want a 1080p monitor, not higher.
I'm torn between two possibilities: the better image reproduction of a budget IPS panel and the Freesync capability of a TN panel in my budget. I live in Germany and the model range available here is not the same as the one in the USA for example. So I can only look through the possibilities available to me. I have selected the following:
IPS: Acer R231 23" or the Acer R241Ybmid 23.8" - both are 1080p, 60Hz, 4 ms GTG, No Freesync
TN: AOC G2460PF - 1080p, 144Hz, 1ms GTG, Freesync
The components I have finalized:
Core i5 6600K
MSI Z170-A motherboard
G.Skill Ripjaws V 4x2 GB DDR4
RX 480 8GB
Thanks for the help
Core i5 6600K
RX 480 8GB
Thanks for the help
