144hz+gtx 1050ti problem
Blaze_4
7
So my current monitor is 60hz with hdmi cable , and i ordered a 144hz monitor, will it work with gtx 1050 ti? just with hdmi cable or will i get still low fps because of the hdmi cable? Do i have to get some converter hdmi>dvi to get higher fps does this work?
Any fps increasing?
Ps i play overwatch
The HDMI cable shouldn't be the problem...
Try updating your drivers for a start.
If that doesn't work reply back and I will supply further assistance
Good Luck!
Good Luck!
