144hz, IPS, 24inch Monitor with low Input Lag
titusz
7
Hello everyone.
Is there any monitor that has:
- IPS panel
- low Input Lag
- 144hz freshrate
- size of 24inch?
Dont need Freesync or G-sync.
AFAIK all 144 Hz IPS monitors are 27" or larger. There are some 24" VA panels like the C24FG73 though, if you don't mind a curved display.
(Edited)
I thought I typed 73 originally, thanks for catching that :3
The size of 24inch, the low input lag and the 144hz refresh rate is the most important factor for me. I have to accept that there is no 24inch monitor with IPS panel.
So i checked the 'Monitor Input Lag Database' since the manufacturer does not apply this information to their products, and i found the 'BenQ XL2411' monitor, that has 144hz refresh rate, 10 ms input lag, it is 24inch wide and has 1ms response time. The only downside is that it has TN panel that i dont know how good or bad. I mainly play video games like CS:GO, Smit, Warframe...
I know IPS panel has better view angle, color. But is it worth that much, or the TN panel is just underrated?
I can't finde any source or documentation concerning this monitor's input lag. Do you know how much input lag it has, or any source related?
