That card has 3 DP ports. No that is not possible. Are you looking at the back of the GPU? Not the motherboard IO where your USB ports, Ethernet, and such are. The GPU should be below that, this is where you plug in your display cable.gtx 1660 msi gaming x
is it possible that even if compatible the people that assembled my pc didn't put it on the outside? i'm sorry i'm not really competent, maybe i'ìm so dumb i can't see it lol.
Im pretty sure you have display port. What model GTX 1660 is that? I think they all have at least one display port.
Yes, if your monitor has a DVI port or supports 144 Hz over HDMI.
There's a list of monitors that support 144 Hz over HDMI in section 7 here: https://forums.tomshardware.com/threads/how-to-connect-to-a-120-hz-display.3268285/
https://ibb.co/ZM36Xvt thanks a lot for your helpThat card has 3 DP ports. No that is not possible. Are you looking at the back of the GPU? Not the motherboard IO where your USB ports, Ethernet, and such are. The GPU should be below that, this is where you plug in your display cable.
Take a picture of the back of your PC and post it if you are still confused.
That is correct.so if i undertsand correctly if the monitor has a dvi port, having the pc a dual link dvi-d, it should reach 144hz on a 144hz monitor?
