144hz monitor help please
LukeH97
15
Hello guys i was wondering if i brought a 144hz monitor but some of my games don't run above 144fps will it still seem smooth or will it be choppy? thanks :)
Well. That really depends on the GPU you will be using and also the resolution at which you will be playing. 144hz is the refresh rate for the monitor screen. It will refresh that fast but the data transferred to it from the GPU has to be at that rate. Probably it will be okay.
I will be using the gtx 750ti at 1080p how does that sound?
