I have an AOC G2460PQU monitor that is capable of running 1080p@144hz. But in nvidia control panel and windows it shows max refresh rate as 60hz and I can't go higher. I am connecting via display port.
In the nvidia control panel when it has you choose the resolution you need to scroll down to where is say PC and select 1920x1080 for 120 and 144hz to be an option on the side. If you select 1080p under the Ultra HD, HD, SD section 144hz wont be an option.
there is no option for 1920x1080 under where it says pc
