It depends. For example, in what resolution will you be gaming? I look at it this way:
If you are planning to be gaming on a 1440p monitor then the 144hz will probably not be worth it for now, as you will probably not hit high enough FPS on the gfx intense games. Your choice will be easy then.
However, if you will be staying on 1080p then you will have a lot of things to decide on. You can get a nice 1080p 144hz TN panel for a decent price, or you can try to find a 1080p IPS panel that suits your needs. I've got the GTX 970 as well and buying a new monitor right now is proving very tough indeed. So good luck!
