144hz monitor running in 60 hz
BreaK_TV
Commendable
Sep 29, 2016
38
Hello i have a problem with my monitor : LED LG Gaming 24GM77-B 24"
I have it connected from my 1080ti with display port cable. Even if i have sellected 144hz in nvidia control pannel and windows display proprieties tab my monitor run's in 60hz only....
I used this website " https://www.testufo.com " to test it and i only recive 60 hz.... i remember when i had the monitor viad dvi cable i was reciving 144hz but since i have a dual stream pc setup i had to move it to display port.... any idead why this happends ?
Use Firefox, the test doesn't work properly on chrome.
BreaK_TV
Commendable
Sep 29, 2016
38
The problem is that i'm using a dual stream pc and i need to connect my elgato 60 pro and when i connect it my monitor runs in 60hz...
If you are duplicating display, both displays will have the same refresh rate.
BreaK_TV
Commendable
Sep 29, 2016
38
Yes i know that but still they are on 144hz and the main one runs at 60 hz/....
