144mhz Monitor for Gaming How much what Size is good
williamseattle
147
I was told to get a 144 mhz Monitor for Gaming like Star wars battlefront. How much and what Size is good for gaming. Atm i Play on a 50 inch tv with 60hz and was told to Upgrade to a Faster Monitor. Any Help Great or Prices or Links Thanks !!
Do you have a particular budget you're working with? For an AMD GPU equipped rig, FreeSync monitors are typically affordable:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824116781
http://www.viewsonic.com/us/vx2757-mhd-2.html
Though this is a 75hz monitor, not 144hz. With the video card you have, and for most intents and purposes, this is still a very smooth monitor, but for a higher refresh rate in the same range, this would be worth a look:
https://www.amazon.com/AOC-G2460PF-24-Inch-Gaming-Monitor/dp/B01BV1XBEI?ie=UTF8&tag=pcpapi-20
What does the rest of your system look like (please list)?
Also, monitors with adaptive sync technology are are almost more important than refresh rates greater than 60hz if you're looking for buttery-smooth playback, though many adaptive sync monitors also come with higher refresh rates as well.
current system Amd Fx 6350 3.9 cpu not Oced 8 gigs dual 4 gigs mem sticks=8 gigs windows 10 64 bit 1 128 ssd and 1 terabyte hd western blue 1 16x dvd-r lite on burner AsRock 960m/U3S3 Fx MB with ASUS R9 Radeon 380 OC Strix Gaming Video card. with 50 inch 60 hz refresh rate screen. Yes good Big screen but not Liquidy Butter Smoth Playback on Screen when gaming unles you Drop Resolution on games to 720ish screen size and less graphics.
