15-pin power for Seagate Desktop SSHD
Terrorsquad1990
273
Hey all,
I was wondering if the Seagate Desktop SSHD contains the 15-pin power cable included with the SSHD.
I can't seem to find the info about it.
Would be nice if I dont have to buy the 15-pin power cable separately
Thanks
The power cables are part of your power supply. You don't need to buy a separate cable. You just use one of the many SATA power connections your power supply should have.
The vast majority of PSU's have multiple SATA power connectors.
It may need another SATA data cable, though.
And I seriously hope the OP is still not wondering about this 2 years later.
