$1500+ Gaming Build! Need help with suggestions!
krazyt2528
17
Here is what I have for my build.
I am looking for suggestions to help make the build better.
CPU Intel Core i5-3570K 3.4GHz Quad-Core $209.98
CPU Cooler Corsair H100i 77.0 CFM Liquid $99.99
Motherboard MSI Z77A-G45 Gaming ATX LGA1155 $124.98
Memory Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 $87.32
Storage Sandisk Ultra Plus 256GB 2.5" SSD $162.99
Seagate Barracuda 3TB 3.5" 7200RPM $129.99
Video Card MSI GeForce GTX 780 3GB $520.98
Case Cooler Master Storm Scout 2 (Black) ATX Mid Tower $99.99
Case Fan Corsair Air Series SP120 Quiet Edition (2-Pack) 37.9 CFM 120mm $27.98
Power Supply Corsair 800W ATX12V $84.99
Optical Drive Lite-On iHAS124-04 DVD/CD Writer $16.98
Operating System Microsoft Microsoft Windows 8.1 - 64-bit - OEM (64-bit) $99.99
Thanks
Cpu's fine, I'd look at the Z77 Ex 4 I mentioned before, got one when they first came out and figured I'd switch to a Asus ROG mobo but never a reason to, still am using it (3570K at 4.7, 32GB of Trident 2400 sticks, use it same as my Haswell to test components for new builds, upgrades, repairs etc, have had up to 780s in it in SLI, takes all I throw at it
Tradesman1
Legenda in Aeternum
Nice build, would change the mobo, I won't touch MSI for builds, poor QC, might look at the ASRock Z77 Extreme 4, best rated and selling Z77, also if not looking to SLI in the future could cut back on the PSU, for a 780 a 600 with 42AMPs on the 12 volt rail is sufficient
krazyt2528
17
im new to the gaming desktops. I feel like oc'ing would be a good idea but I would rather have components good straight out of back. What in my build can be swapped for a non oc build. Also, I am new to building so if 4670k and z78 is better than I would rather use that.
Thanks
krazyt2528
17
I feel as I would end up SLI in the near future so I added the beefy PSU
Tradesman1
Legenda in Aeternum
krazyt2528
17
Motherboard ASRock Z77 Extreme4 ATX LGA1155 $124.98
Memory Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-1866 Combo or $86.99
Video Card MSI GeForce GTX 780 3GB Combo or $541.81
Power Supply Corsair 650W ATX12V / EPS12V $59.99
I updated the list to peoples suggestions. Am I missing anything else?
leeb2013
then the k processor and Z77/87 mobo is not really required and neither is water cooling.
But if you might xfire/sli in the future, you'll need 2 PCI3.0 x16(x8) slots which usually means using a Z77/87 mobo anyway and definitely a 750-800W PSU too.
Although if you get a lower power PSU it might handle it, you don't really want to be running it at 100% all the time, so a bit of headroom is best.
TheRealShoe
126
Which at that point he might as well spend the extra $20 on the "k" processor, in case he wants to OC down the line.
leeb2013
might as well, I did after first saying I wasn't interested in o/c and it's awesome LOL! Makes you feel like you're getting an extra 30-40% performance for $20. Same with GPUs!
Latest posts
