bubasvabac,
On behalf of Tom's Moderator Team, welcome aboard!
Intel’s specification for Digital Thermal Sensor (DTS) accuracy is +/- 5°C. This means deviations between the highest and lowest Cores can be up to 10°C. Deviations on processors that have an uneven application of TIM might exceed 10°C by several degrees.
However, as
Barty1884 pointed out, if your cooler is properly installed and the TIM is applied correctly, then the problem is under the IHS. Keep in mind that your Devil's Canyon 4690K was launched in the 2nd Quarter of 2013, so yours could now be over 5 years old. Intel reportedly changed to a "polymer" TIM after the temperature disasters of the Ivy Bridge and Haswell processors, so Devil's Canyon is now mature enough for evidence of TIM failures to become apparent.
I very recently delidded a 4690K with exactly the same thermal behaviors you've described. Before delidding, deviations between Cores was about 18 to 20°C. After delidding, deviations under the same test conditions decreased to 6°C, which is well within the 10°C (+ / - 5°C) spec. Overall Core temperatures also decreased by about 16°C, so it was a win-win scenario.
You might want to consider delidding, which
will fix the problem. If you've never delidded and don't want to try the razor blade method, you can safely delid with a "delidding tool" such as the Rockit 88 - https://rockitcool.myshopify.com/
Delidding requires that you use
only liquid metal TIM between the Die and IHS. Typical silicon TIM will fail in a relatively brief period of time. A process known as “pump-out” will cause silicon TIM to ooze out from between the Die and IHS due to thermal cycling. A highly recommended liquid metal TIM is Thermal Grizzly Conductonaut -
http://www.thermal-grizzly.com/en/products/26-conductonaut-en
Silicon Lottery -
https://siliconlottery.com/collections/all/products/delid - is a company that tests, bins and sells overclocked, delidded "K" CPU's. They also offer professional delidding services, which is always a good option.
Also, we have a Sticky you might want to read:
Intel CPU Temperature Guide -
http://www.tomshardware.com/forum/id-1800828/intel-temperature-guide.html
Once again, welcome aboard!
CT
