It's DDR3 memory, and the base is "800MHz" (2x400MHz):
http://www.msi.com/product/mb/G41M-P23.html#hero-specification
*I couldn't tell from the picture of your memory, but if it's listed as "1600Mhz" memory then each module would run at 800MHz in Dual Channel mode (the data is split between two module so it's an "effective" 1600Mhz speed).
Your motherboard can still DEFAULT to its lowest (800MHz-> 2x400MHz) even if the memory is capable of TWICE that speed.
**Note the motherboard link states 800/1066/1333*(OC) which means overclocking is involved to get to 1333MHz (though beyond that is apparently impossible).
NOTE: I would attempt to enable "XMP" if that exists to see if that changes anything, or read the motherboard manual carefully or Google that exact board for more information if you want.
It may make little to no real-world difference in performance however, but if you can get to 1066MHz or 1333MHz (with overclocking) then you might want to try.
No matter what, use MEMTEST to validate (use for two minutes and a final "FULL PASS" to be fairly sure). www.memtest.org
(may need to change BOOT ORDER in BIOS to get Memtest to boot from DVD/USB)
