Hello any one have knowledge or facing same problem of 1600 MHz CL-11 RAM actually running at 1066 MHz CL-7 IN Toshiba Satellite C55-A5300 /PART # PSCFEU-00M00G
Recently bought New 8 gb ram of Silicon Power 8GB-DDR3L-1600MHz (PC3 12800) 204 pin CL11 1.35V Non-ECC Un-buffered SODIMM-Laptop Memory Module - Low Voltage and Power Saving. When I do multi-tasking that time its work slow or legging and sometime jittering. my laptop BIOS Insyde v1.30 window 10 home recently upgrade from window 8.1. I have only one memory slot (big Surprise)[ which I recognize after warranty and return time gone]. I usually use daily regular work multi task not game so now I can’t change speed from bios because no ram speed setting available. I do not have any advance settings on my BIOS. The ADVANCED TAB is hidden or not available I don’t know. I spent over 20 hours looking for how to unlock these settings but failed. I tried all the options.
Window 10 task manager show me 8 GB ram and 1066 MHz speed. HWiNFO64 diagnostic tool show me two different clock 533 MHz and Clock 800 MHz.Memory timing 7-7-7-19
so how I set 1600 MHz speed ?
or Do this ram module is faulty? I can’t understand
i attached my old ram report image,and new ram report following
New ram report
Detailed Specifications for Satellite C55-A5300
New ram report
