Hi All, thanks for the add! I need some info on a 16Tb SSD external Drive I purchased, It wont keep data as I did purchase it for storage, I copied a whole lot of data over and when I wen to add more later on the drive was empty. have formated it to exfat, alls fine, but then I decided to format to NTFS and see if this sorts out the problem, well after 6 days came up with an error of (The second NTFS boot sector is unwritable) and then ( The first NTFS boot sector is unwritable) and then (All NTFS boot sectors are unwritable) cannot continue, Format Failed, Format Failed?? seems I cannot add a screenshot of the windows error anyone got any ideas on how to fix or just dump them?
