Question 18 pin to 24 pin?
Sep 22, 2021
Hello out there! I am trying to power a second graphics card but my 1200w power supply doesn't have enough pcie ports. I bought a second 500w power supply to power just the gpu and a 24pin adapter cable for dual power supplies. The 1200w psu has a 18pin power port however so will not work with the 24 pin adapter. Any advice at all would be extremely appreciated!
lvt
Respectable
Apr 19, 2021
1,803
301
1,840
72
Can you explain more in details?
The 1,200W PSU is the main PSU and the 500W is auxiliary PSU for the GPU, right?
What was the 24-pin adapter used for? The motherboard?
--SID--
Commendable
Jan 23, 2021
1,328
280
1,340
59
What make and model 1200w PSU? A quality 1200w PSU used to have 8 PCI-e connectors!
Make and model?
I guess the pinout is different. You have to measure the pinout on the 18p connector and compare it to the pinout of the 24p connector.
