$180 + 256GB SSD = Help
Tinchox
4
Hi, i have like $180 for a new ssd
For, gaming, video rendering, etc
with one of this is the best
Crucial MX100
SandDisk Extreme Pro
Samsung 850 Pro
im using Windows 8.1 pro
go for crucial i use that and i had no problem ? !!!!! my comp need 3.5 sec to be in Windows 8.1
Brand: Crucial
Form Factor: 2.5-inch internal SSD
Module Size: 256GB
Warranty: Limited 3-year
Specs: Crucial MX100 256GB SATA 6Gbps 2.5" Internal SSD • 550 MB/s Read / 333 MB/s Write
Series: MX100
Product Line: Client SSD
Interface: SATA 6.0Gb/s
Part number: CT256MX100SSD1
Form Factor/Type - The physical size of the hardware components in your system. For example, the form factor for an SSD might be 2.5 inches or 1.8 inches, which tells you the dimensions of the SSD.
Interface - An interface is the means by which two independent systems communicate. For SSDs, the interface refers to a connector that plugs your SSD into your computer so it can receive power or data.
Read - In computer terms, a "read" refers to accessing a piece of data from a storage device or memory.
SATA - Serial Advanced Technology Attachment. It's a type of interface that connects a storage device or optical drive to your computer's motherboard—think of it like an umbilical cord because it allows data to flow between the two. SATA is measured by how fast data transfers to/from the device. There are three SATA speeds, SATA I (1.5Gb/s), SATA II (3.0Gb/s) and SATA III (6.0Gb/s).
Write - In computer terms, "write" refers to how quickly a piece of data can be saved to a storage device (saving a document is an example of a write function).
