Hello,
I need some help with building a PC for architectural rendering and modeling in c4d/archicad, 3dsmax ... Vray, corona.
At the moment I have this build in mind: https://de.pcpartpicker.com/list/sQ9Ymq
Because it is a bit more expensive than I wish and the rendering is based on CPU, I thought I could switch the GPU to a EVGA – GeForce GTX 1060 6GB 6GB SC GAMING Video Card ... or would that be a big mistake for a 200€ price differance?
Is the cooling sufficient or would you recommend anything else.
I was also deciding between the intel i7 8700K and ryzen 7 2700x CPUs.
I can only purchase on Amazon.de and would wish for the price to be around 1800€, but I will spend 2000€ on the build above if it will greatly improve the performance.
I would be very grateful for any comments or recommendations from somebody with more knowledge about this type of build.
Thank you
Greetings
Thank you
Greetings
