Hi all-
I am preparing to convert an 18v NiCad tool to Li-Ion (my first conversion!). I've got some new high-discharge Li-Ion 18650 batteries, access to a battery spot welder, and a 5-cell BMS board.
If all goes well, I will have 5 cells in series (~18v) and if I have room, a second series of 5 in parallel to reduce the draw by splitting it across the two series of cells.
So here's the question- I want to include a voltage converter in my design so I can use the original battery charger, but converted to the correct voltage. I have two original chargers, I think one is 21v and one is 24, both are very low amperage. I'm thinking a DC-DC converter to get the voltage into the correct range, I don't mind if it trickle charges for a long time to reach charge, I don't use these tools often.
So: If a single cell charges at 4.2, I'm assuming the BMS is (in essence) charging each cell independently rather than the series of 5 cells, so I should get a converter that gets me to 4.2, is that correct?
Are there any *risks* to charging this slowly (low amperage)? For example, will a standard BMS think that the charging is so slow it will shut itself off? Will too-slow charging have any negative impact on the batteries themselves?
Many thanks!
Many thanks!
