I have a budget monitor. It's a Viewsonic E95. It's not flat but not badly curved either. Has good uniform color with no warm or cold spots. Sharp focus right to the corners (well to 1/4 inch from the corner). Has all the control features you'd expect with a budget monitor plus vertical and horizontal moire and focus adjustments. Max resolution is 1600 x 1200. Dot pitch is .26 mm <b>[<-- correction]</b> (.22 mm horizontal).
Downsides: Only 76 Hz refresh at 1600 x 1200. Menu is awkward.
Upsides: Doesn't have the visible wire lines of AG monitors.
I would have prefered buying a monitor that I could actually see in person but I couldn't find anything I liked locally that was close to my budget, $200.
The E95 was only $203 delivered so I took a chance. It worked out well. I'm really happy with it.
<b>56K, slow and steady does not win the race on internet!</b><P ID="edit"><FONT SIZE=-1><EM>Edited by phsstpok on 05/31/03 09:01 PM.</EM></FONT></P>
