G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I am writing this for anyone out there who has a 1905fp and is
dissapointed with the gamma/brightness. I bought the 1905FP about a
month ago and have been messing with it ever since I got it, and have
finally come up with a pretty good work-around solution.
The moniter's default settings seem to be way off the mark when it
comes to gamma and brightness. The first thing you need to do is do a
windows update when you first install it and download the optional
hardware option that should come up: 1905FP.icm color profile.
Here's the first problem (there are others that I will get to). The ICC
profile is wrong!! So you have to tweak it. Open up Adobe Gamma, choose
control panel, and load the 1905FP.icm profile. DON'T CHANGE ANYTHING
EXCEPT THE PREFURRED GAMMA. Type in 2.65. This will compensate for the
monitor's washed out default internal gamma (which seems to be a major
flaw in it's design.) Save it as a different name (so you can always go
back and change the original if you need to.)
NEXT. Go into the monitor's OSD menu and make sure the Brightness is
set to 100 (default setting). Then go into color settings and go to
User Preset. This is where we compensate for the monitors over the top,
eye blistering brightness. set the colors to this setting: R=85, G=85,
B=80. This lowers the brightness down to a more usable setting. Adjust
to your liking, of course.
Also, as a last check-up. Go to your Display properties > Settings >
Advanced > Color MAnagment, and make sure that the ICC profile you
saved out from before is the default profile. If it is, remove all
others, if there are any there, and restart just to make sure it set's
itself as the default.
Hope this helps.
It's still not totally perfect, but it's definitely a good solution
while you save up for a more color calibrated monitor. (Which is what
I'm doing.)
CP333
Hope this helps.
I'm doing.)
CP333
