Hi.
I usually use my monitor with a VGA input, and i know that that is not ideal as i do want the sound with HDMI connection, but when I do connect via HDMI the normal resolution that I use (1680x1050) with VGA looks nothing like it does normally.
When connected to HDMI the resolution that it bumps up to that actually looks decent (1920x1080) does not fit the screen and it goes off of the edge.
Can anyone help? I can get images if that helps?
Thanks in advance
http://imgur.com/a/YMxE6 album to show what i'm on about
Thanks in advance
