1GB EVGA GT 610, PCIe 2.0 (x16), 1000MHz GDDR3, GPU 810MHz, Shader 1620MHz
sn3eky
28
Hello,
I bought this GPU refurbished for £20. I only bought it as I run 2 displays and decided to run one display off this GPU to take the strain off my main GPU when playing games on it.
I've placed it into my PC and booted my PC. However I can't get the drivers. I installed nvidia experience and downloaded the drivers, but when trying to install drivers it says failed.
I went to the eVGA website and downloaded the drivers, it also fails on installation.
What else can I do to fix this issue? The GPU is running incredibly poor without drivers.
Thank you for any help you can give
My specs:
128GB Samsung SSD
1TB HDD
intel i5 750 3.4GHz
nvidia Geforce GTS 250
W7 64-bit
Even with drivers the performance will be poor ;-). You might want to start fresh, download and run DDU, and install video drivers again.
