1GB GDDR5 192bit Gtx460 OR R7 260X 2GB GDDR5 128BIT
berdugo1020
135
hello experts im building this setup
CPU: AMD FX-6300
RAM: 8GB Kingston DDR3 1600Mhz
MOBO: MSI 760GM-P23 FX AM3+
CASE: Aerocool Vs3 - Advance
PSU: AEROCOOL STRIKE-X 600W MODULAR
GPU: should i still use GTX 460 ? or Replace it with R7 260x ?
which is better ? i have seen the gaming power of the both .. much the same ?
Yes it will be perfectly fine. Don't forget to pick a solution. :)
so i should go for r7 260x thanks a lot ..
and if ever do you know if the kingston hyper fuxy will work fine on my setup ?
Yes, the R7 260X is a wise and sensible choice if you are contemplating between the 460. Anyways, the Z87 should be fine and will fit the Kingston Hyper Fury. But how much memory are putting in?
only 8GB lol .. that'll be fine for me .. is that alright ?
