1st Build Hardware Help
The_Cloak
Hello everyone, I'm a first timer with building a PC, so I thought it would be wise to ask some more experienced peoples' advice before I get started. I have what I believe is most of the necessary parts picked out, so I was hoping some of you could check it out to see if I'm missing something or some of these parts aren't compatible. Hoping for a decent gaming PC, not planning on Crossfire/SLI though. Thanks in advance!
Here's what I have my eyes on:
Case:
-Rosewill Challenger U3
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147060
Power Supply:
-Apevia ATX-AS680W ?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817148022
CPU:
-Intel Core i5-3570k Ivy Bridge
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Motherboard:
-Biostar TZ77B
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138352
GPU:
-XFX Radeon HD 7850
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150608
RAM:
-G.Skill Ripjaws 8GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231311
Didn't forget the hard drive, just browsing still lol.
