1st build rate/ opinion / help
Some1helpme
102
4
18,685
Want to get you guys' opinion on my 1st true complete build.
Parts:
I7 8700 (non k?
16 gb corsair vengeance ddr4
Zotac gtx 1080 ti
Asrock z370 extreme4
Corsair rm 750x
Samsung 970 evo m.2 nvme 500gb.
Corsair 460x case
So the case comes with 3 rgb fans and a fan hub to control them. Added a 4th one for exhaust. Want to get an rgn strip but corsair support says you cant plug in strip to the hub that controls the fans rgn. How would you guys go about doing it? Motherboard has ab rgb header but then case fans, mobo and rgb strip would be all out of whack.
https://ibb.co/c42Luf
https://ibb.co/iLaC70
https://ibb.co/keSs70
https://ibb.co/cPoRZf
Where it's at and the home made table isn't permanent so dont judge that to much
Hey! The 460X comes with Corsair SP-RGB fans so keep that in mind.
For an in-depth discussion of all things Corsair RGB, start with this FAQ: http://forum.corsair.com/v3/showthread.php?t=173880. That'll help you begin to put the pieces together.
