1st build system
ragecat
Hi,
Any compatibility issues with my rig here?
xeon e3 1230v3
asrock h87 performance
evga780 superclock
2x8gb team elite 1.35v cl11-11-11-28 ddr 3 ram
1tb WD blue
cooler master gx650w
quick question about the 1.35v ram. any issues with it? is it possible to up the voltage to standard 1.5v?
Thank you
i figured a xeon as i wont overclock the system. budget is pretty free float at the moment, but i am building the system around the gpu. I'll be gaming with some heavy duty data crunching, figured i'll need the 8 threads at some point!
already purchased the gpu + casing + ram + psu. but will probably resell the psu for something else!
