CPU/APU: AMD A10 5800k
MB: Asus A55M-E
RAM: (2x) 4gb HyperX 1600MHz
GPU: XFX Radeon HD 6670
A couple of months ago I finished my first PC build that would be mainly used for gaming. So far, I have been just relying soley on the APU for graphics so I decided that i should get a discrete GPU to pair with it. As soon the GPU got delivered, I immediately tried to install it in PC but I ran into some dilemmas along the way.
First off, the GPU did not fit on my motherboard due to the fact that the metal bracket that you screw onto the case was too long and made contact with the motherboard making installation nearly impossible. To remedy this, I bent the portion that made contact with the motherboard back so it can be installed properly. After doing so, i followed the usual steps for proper installation (download drivers and so on...) but now... I'm stuck.
My question is this: Can someone please give me a detailed step by step guide on how to set up dual graphics for my PC? I know it's asking a lot but i honestly do not know what to do from here.
Thank You for your time
MB: Asus A55M-E
