Hi Everyone
I'm getting ready to build my first PC and I was hoping to know if there was anything more I could do to improve my first build. I've been researching parts for the last 5 weeks so far and I think I have it down. Here is my setup so far. (note: I haven't bought these parts yet, except for the GPU)
CPU: Intel Core i7-7700K $339.99
https://www.newegg.com/Product/Product.aspx?Item=N82E16819117726
CPU Cooler: Nocuta NH D15 $87.99
https://www.newegg.com/Product/Product.aspx?Item=N82E16835608045
Motherboard: MSI: Z270 Gaming Pro Carbon $164.99
https://www.newegg.com/Product/Product.aspx?Item=N82E16813130973
GPU: ASUS Strix 1070ti $650
https://www.newegg.com/Product/Product.aspx?Item=9SIA85V6UM4858&cm_re=asus_strix_1070ti-_-9SIA85V6UM4858-_-Product
RAM: G.SKILL Trident Z RGB 16gb (2x8) DDR4 3000 RAM $229.99
https://www.newegg.com/Product/Product.aspx?Item=N82E16820232498
Optical Drive: Pioneer 16x BDR-211UBK Internal UHD 4K Blu-ray player/writer $159.99
https://www.newegg.com/Product/Product.aspx?Item=9SIA3V65XV3802
PSU: Thermaltake Toughpower Grand RGB 850W $119.99
https://www.newegg.com/Product/Product.aspx?Item=N82E16817153311
WLAN: Rosewill RNX-AC1900PCE $59.99
https://www.newegg.com/Product/Product.aspx?Item=N82E16833166121
PC Case: RAIDMAX ALPHA Prime $75.19
https://www.newegg.com/Product/Product.aspx?Item=N82E16811156365
Monitor: ASUS MG28UQ Black 28" $419.99
https://www.newegg.com/Product/Product.aspx?Item=N82E16824236688
OS: Windows 10 Home - 32&64 bit Full Version $129.99
https://www.newegg.com/Product/Product.aspx?Item=N82E16832397825
Edit: Almost forgot the storage
Seagate 2TB HDD 7200RPM $79.99
from a random store at Best Buy.
So as you may have noticed, I am going with an RGB build at 4k. My main concern for performance is the CPU cooler which is good but not ideal for some Overclocking. I do want to try some liquid cooling but my choices are limited as I am going with an RGB build. my budget is $2500
My first option is
Thermaltake Floe AIO Riing RGB 240 TT Premium Edition
https://www.newegg.com/Product/Product.aspx?Item=N82E16835106505&cm_re=Thermaltake_RGB_liquid_cooling-_-35-106-505-_-Product
but I am not entirely sure if it is compatible with my PC case. Most notably, to place it on the top fan section without losing the optical drive.
Please, if there is any suggestions you can spare I would greatly appreciate it.
Thank You.
My first option is
Thank You.
