Question 1x8 pin power connector psu on 2x8 pin power connector motherboard
Jun 23, 2023
8
Hi, im new and i currently trying to build my first pc, im using Asrock b760 pro rs motherboard, the thing is my motherboard have 2x8 pin power connector while my psu only had 1x8 pin connector, can i use only 1x8 pin power connector to the motherboard?
What are ALL the components involved here?
Make/model of everything.
im using this, well this is not exactly the stuff im using but close
Intel Core i5-13600K 3.5 GHz 14-Core Processor15W - 181W
ID-COOLING FROSTFLOW X 74.5 CFM Liquid CPU Cooler10W - 15W
ASRock B760 Pro RS ATX LGA1700 Motherboard17W - 70W
ADATA XPG LANCER RGB 16 GB (1 x 16 GB) DDR5-5200 CL38 Memory12W
TEAMGROUP MP33 512 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive2W - 10W
Gigabyte EAGLE GeForce RTX 4060 Ti 8 GB Video Card41W - 165W
and EVGA Supernova 650 GT
The second 8-way motherboard power connector really comes into its own in the unlikely event you're trying to win overclocking contests with liquid Nitrogen cooling. With two 8-way power leads plugged in, the overall resistance is reduced, allowing the CPU to draw more current for the same Volt drop along the cables. When the CPU is pulling instantaneous currents of tens or hundreds of Amps from the 12V PSU supply rail, even a few milliOhms can make a difference to CPU stability.
Reactions: mightybaboon
