Question 2 (6) pin Delta DPS-650PB A for GPU?
silversmithy
467
14
18,785
Need to test a used GTX 980 and I need to use an old Lenovo Thinkstation S10 due to physical size of card. The S10 has a Delta DPS-650PB A PSU. It is a 650w PSU, and has 2 (6) pin connectors one of which shows P11 in white lettering on it. I know typically the cables for the GPU are labeled PCI-E.
I want to make sure that these 2 (6) pin cables will work in the 2 (6) pin connectors on the GPU.
System is an S10 with Q6600 over clocked to 3ghz with bsel mod.
8 gb ddr3 registered ram
Single DVD
MSI GTX 980 afterburner
Again I just want to be able to test the card for general functionality.
Thanks for any advice/help.
This psu?
https://www.ebay.com/itm/225007184994
if the two on the top right hand side in the next picture, those are pcie connectors yes, both of them.They should fit, if any force needed because they don't fit don't use them.
think the white are all for the motherboard, the sata/molex are black and the pcie as well.
Reactions: silversmithy
