2 Cards - 3 Monitors - Problem
rhym1n
307
I am using 2 AMD Radeon HD 5700 Series video cards. I just got my 20 foot HDMI cable in. Last night I hooked up my HDTV to my PC, extended the display, and all 3 displays worked flawlessly together.
Today, I downloaded the most recent video drivers, and I can't get a 3rd display to work. (It did enable crossfire when the new drivers downloaded, but I disabled crossfire, and the 3rd monitor still won't work).
I go into the Windows 7 display settings, choose Extend desktop to this display on my HDTV, and it says "Unable to save display settings."
Surely the new driver would allow for 3 monitors?
rhym1n
307
Well, problem solved, but I have no idea why this happened...
I forgot that last night, I plugged in my HDMI cable on the bottom card to my 3rd monitor (HDTV). Today, when I plugged it back in, I plugged it into the HDMI port on my top card.
When I switched it back to the bottom card, it worked. I now have extended desktops on all 3 displays. Why in the world does that matter?
So you are using the primary and the secondary card at the same time? I am guessing that you may not have enabled Crossfire then, as for why it works now but didn't before only AMD can explain the mysteries of their drivers.
rhym1n
307
I am not using crossfire. That's why I'm confused as to why the primary card didn't work with 2 connections, but the bottom one does.
Again, my top card has 1 connection to a 27 inch monitor. My secondary card is connected to my 24 inch monitor, and my 42 inch LCD TV. All 3 monitors are working as extended displays.
