2 Different gpus same PC help
Un1versa1
Commendable
Jan 17, 2017
So I have GTX 960 strix 2gb card and have a Gigabyte AMD Radeon RX 570 4GB card, I currently use a 3 monitor set up for streaming and multi tasking, my question is can I use both these cards on one rig, I would like to use the RX 570 dedicated gaming and my main display, and my 960 for running the other 2 displays I use for xsplit and tv and so on, is this possible?
thanks for any help
Yes its possible, set up your RX 570 first as your initial display and get that working, then add in the GTX 960 and install those drivers to run it. Ensure the RX 570 is installed in the closest slot to the CPU.
Thank you very much Rogue Leader
