Question 2 Fans spinning at full speed on Asus GTX 1080 Ti ?
Saky94
31
Hi community,
I have this weird issue on my Asus Strix GTX1080ti.
I'll start with my specs:
9700k with an Asus prime z390-a motherboard
16 GB of ram
PSU is XPG core reactor 750 watts ( 1.5 years old)
GPU 1080 Asus Strix almost 4 years old
The issue:
2 out of 3 fans on my GPU start spinning at full speed after I boot up my pc. It happens randomly when I'm not gaming, sometimes after 5 minutes, sometimes after 10 but it do happens at some point. They don't go back to idle mode even when the temps is below 40 until I restart and then the cycle repeats.
While gaming it starts happening almost immediately as the temperature rises and they stay like that even when I close the game and until I restart.
There is no effect on the performance of the GPU at all.
Also for some reason all the tools show the RPM as 0 and I can not control the speed manually using any of the tools(MSI afterburner, Asus GPU tweak etc)
I recently serviced the GPU by changing the thermal pads and the thermal paste.
Strangely once this issue started happening, I opened it up again and changed the thermal paste and when I did it worked fine for 2 3 days and then started happening again, I tried changing the paste again twice and again it works fine for 2 3 days then going back to the same routine of going out of control at every boot.
I was using a cheap quality paste before but then I got a better one which is thermal grizzly kryonaut but I don't think that should affect this issue.
I'm honestly confused as to what the issue can be
Any help would be appreciated.
Attaching an image of CPUID while my GPU's 2 fans spin at full and it shows 0 RPM
<blockquote class="imgur-embed-pub" lang="en" data-id="a/nRzZZCj" data-context="false" ><a href="//imgur.com/a/nRzZZCj"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
View: https://imgur.com/a/nRzZZCj
