In theory, yes. It would work. In reality, you're risking a $400 graphics card on essentially a hot wire job. Do yourself a favor. If you can afford a $400 graphics card, you can afford to repurchase the appropriate cables.
Without knowing your PSU, I'm not even sure if what you're doing is safe *now*.
This is my psu https://www.amazon.com/Cooler-Master-Silent-Pro-RS600-AMBAD3-US/dp/B001NJ0CYG?th=1 I lost the cables for the pcie so ive been running my palit jetstream 670 with it through 4 molex connectors to 2 6pins. From my understanding the 670 uses 185W under load, whilst the 1070 uses 150W. Am I correct to assume my suggested set up will power the 1070?
