2 molex to 8pin PCIE safe for my power supply?
asealmohmand
7
So i have this power supply.http://www.newegg.com/Product/Product.aspx?Item=N82E16817148054&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Power+Supplies-_-N82E16817148054&gclid=CjwKEAjw-Oy_BRDg4Iqok57a4kcSJADsuDK13JgzT1H5d0958DxPMbEZzhYdRq2zEq5yfeWLbTYsXxoC6T_w_wcB&gclsrc=aw.ds
I want to know if it will be good enough to support my GTX 1060 FTW with 2molex to 8pin PCIE connector
One question: WHY? Why the hell would you buy GTX 1060 for 300+ $ and use it with cheapest power supply you can find. There is no common sense to do this.
It has got high chances to burn it out and warranty would not cover it. so if you wanna save your money buy better power supply :)
Yes you could pair them, it will work, but do not do it please :)
But it is too big risk to upgrade videocard with this PSU. It is waste of money and nerves if you burn it. Also what cpu and rams do you have. If is old maby you will have bottlenecked GPU. Or even motherboard will not support it.
I have an i5-6400 and 8gigs of DDR4 ram, rated at 2133 megahertz.
