Hi, I have a project I'm working on. I'm using a 6700k and a 1070 ti in a loop. The loop is being rebuilt in a new case that can only fit one 240mm radiator where I was using two and I have noctua fans. I have 2 Noctua NF-F12 PWM chromax-1500 and 5 Noctua NF-P12 redux-1700 PWM
The build will not be heavily oc'd and was wondering if the two noctua F-12 1500rpm chromax would be enough or should I do push/pull with 4x P12 1700rpm redux, or will the results be similar?
If I can use two fans would be better for room but if the push pull will see a significant difference then I'd go push/pull
