2 pin fan connector
May 26, 2018
9
included with my mobo was a sata to 2 pin cable. the connector itself has 4 pins but I can see that only 2 are going to do anything because only they are actually connected. is it safe to plug in a 200mm phanteks case fan when there are only 2 pins.
Plugging the fan into a SATA power connector from your PSU via the adapter cable you got? Yeah, it's safe, but you won't be able to control the speed (will run at full speed).
great thanks
