I have the Bitfenix Hydra Pro Fan controller and Bitfenix Spectre Pro fans. The controller comes with 2 pin LED connectors that can attach to the fans to be able to switch the LED's on and off. My problem is that these connectors on the controller are only 12" long and I need a way to connect them to fans that are further away. What kind on extensions would work for this purpose?
I was looking at this one. Would it work?
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=34_289&products_id=30649
Thanks.
Thanks.
