2 Problems on my Motherboard!
It takes a lot of force on some motherboards to get the 24 pin cable to go in properly. If the 24 pin cable is a 20 and 4 pin split cable, then you need to make sure you line the two parts of the cable up side by side before you attempt to plug in the cable.
The front case cables will connect to the pins on the board labeled jfp1 and jfp2 (the fp stands for "front panel"). You will need to reference your motherboard manual to see their configuration.
