2 PWR LED CONNECTORS
brybry
31
Hello,
DO I PLUG BOTH PWR LED CONNECTORS IN BOTH HEADERS OF asrock fatal1ty z68 profesional gen3
1 IS 2 PIN . 1 IS 3 PIN .
If your case uses a 2 pin connector (pretty common on newer cases), use the 2 pin header. White wire usually goes on the negative terminal.
If you do get it backwards and the case power LED does not illuminate, just reverse the terminals. You will not hurt anything. If backwards, the LED just will not illuminate.
