yannickhk :
dannyboy2233 :
bystander :
If you get the EVGA 780 ACX, it is just about equal to the Titan. Though you will want space between the cards with that cooler.
There is no DX12 yet, so we have no idea about that. I can only assume it won't support DX12, as the last few DX updates required new hardware
What is your resolution? Perhaps getting 2x EVGA 780 ACX would serve as a better compromise.
If you're going to do Tri-SLI, you really have to think about the temperature aspect. Unless your case is enormous (e.g. a 900D) then the cards will be in three adjacent slots. The top card will be extremely hot, as will the middle card. Unless you can get cards with extremely good cooling, I recommend going dual-SLI Titans since they will be quieter and much easier to cool.
Also, you would be hard-presed to find something (even on a tri-monitor setup) which wouldn't run perfectly with two Titans, especially since they have so much VRAM.
Is there anyone out there using 3 titans/780 in SLI without watercooling them ?
To the OP: I believe that you'd be better off with 3x780s IMO
Im using 3way SLI with the GTX 780 Factory Overclocked by Gigabyte (3Fans each).
My configuration: i7 3970x oc to 4.8 Ghz cooled with Corsair H100i
16GB Corsair Vengeance 2400 Mhz
480 GB Corsair Force GS
Asus Rampage 4 Extreme
My Problem: the Top Card reaches a Temperature of 92c
The Middle one at 85c
and the bottom one at 78c.
I think these temperatures are too high! Dont really know what the solution is. Note that these temps even arise when my case is open at one side.
If i would close the case, the temp would go up and stream through the radiators of my CPU Cooler, what results in bad cooling for my CPU. I dont even dare to
close the case. TO avoid this temp Hell i would need to install an Airplane turbine, where the noise would be so loud that gaming doesnt make fun anymore!
Thats not why i spent so much money and work to make this machine work.
The FPS are amazing reaching 230 FPS with Benchmark apps.
I used to have 2x GTX 690 stock (Asus) and didnt even reach half of 3way GTX 780 results.
My question: what could be the reason for overheating? Is there a solution?
I have a 2 year old daughter and cant keep the case open, can only play at night when she is sleeping....
Please let me know if there is a solution....
P.S. I didn't over clock with software at all since this would increase temps even more...
Thanks
